Skip to content
⌘K
How to subscribe to a paid plan after a trial ends
Updated by Cristopher
Accessing the Cloud console
To subscribe to a paid plan after your trial ends, sign in to the n8n Cloud console (Admin Panel in earlier versions):
  1. Open the Magic Link page and enter the instance owner’s email address.
  2. Select Send magic link.
  3. Check your inbox and follow the link to sign in to the Cloud console. If the email doesn’t arrive, check your spam folder.
Setting up your subscription
Once you are in the Cloud console, you’ll see a Your trial has expired message.
  1. Choose Annual or Monthly billing.
  2. Click on the Upgrade and resume button.
  3. Follow the on-screen instructions to complete your subscription.
  4. Check the countdowns shown on the page. The banner at the top shows the time remaining before your instance is deleted. A separate message below the subscription options shows how much longer your data will be retained. The number of days shown depends on when your trial ended.
Restoring your instance
After your trial ends, you can restore your instance by completing a paid subscription, provided your instance data is still available. Restoration may take a few minutes.
Check the message below the subscription options to see how much time remains before your data is permanently deleted.
Article Last Updated At: 2026-11-02T16:49:12.967Z
